Problem in a foldable system
  • April 28, 2022
  • 141 views
I am trying to place a lens after the prism in  a system containing a tilted mirror at an angle, followed by a non-sequential component(prism), but as the value of radius is inserted there is a sphere of that certain radius, irrespective of the semi aperture diameter. and there is also a star marked on clear- semi diameter.
I am attaching a screenshot for your reference. If any more information is required to understand the problem , please let me know.
Please guide me on how to resolve this issue, with an explanation on why such a problem arises.
Best answer by Jacob.Jikku
I had the same issue after coverting a file from CODE V to Zemax.
Please check the Surface properties --Type and make sure you have selected ”Surface Cannot Be Hyperhemispheric”. I hope it works for you.
  • 17 replies
  • December 13, 2022
