Preferred windows on startup or new file?
  • 29 March 2023
  • 152 views
Hello all,
I am new to the Zemax/OpticStudio community and still learning how to use the program.
I was wondering, is there a way to open windows other than ‘Lens Data’ when creating a new file or on startup?
Thank you for your help
Richard Liao
icon
Best answer by Mark.Nicholson 30 March 2023, 18:23
Userlevel 7
Badge +3
Hi Richard, Yes there is. Do New, then set up the UI the way you want and then save the file as lens.zmx. Alternatively, save it as some other file name and then go to Setup...Project Preferences...General and press the Startup Defaults button:
Choose ‘User Selected System’ and point it to the file you  just saved.
Thank you Mark! I found that this only worked for me when i start OpticStudio but not when starting a new file, but I guess it’s better than nothing.
Cheers,
Richard Liao
Userlevel 7
Badge +3
Try saving your preferred setup as lens.zmx. Make sure it’s in your default folder. Or just load it whenever you want 😁
