POPD Operand through ZPL
How can I set and/or retrieve POPD optimization operand using ZPL?
Also related: Through ZPL I would like to get all the information contained in the POP window: Text and Prop Report. For instance, Pilot beam data and Fiber Efficiency etc.
Cheers!
@Asuku
This is how you would setup a POPD operand in ZPL:
__________________________________________________________________
# Merit Function (MF) Editor row at which the POPD operand will be placed
popd_row = 1
# Create a new MF operand
INSERTMFO popd_row
# Get the POPD type value
popd_type = ONUM("POPD")
# Change the new operand type to POPD
SETOPERAND popd_row, 1, popd_type
# Values of POP columns
surf = 1
wave = 3
field = 2
data = 1
xtr1 = 0.1
xtr2 = 0.1
target = 0.123
weight = 4.567
# Apply values to new operand
SETOPERAND popd_row, 2, surf
SETOPERAND popd_row, 3, wave
SETOPERAND popd_row, 4, field
SETOPERAND popd_row, 5, data
SETOPERAND popd_row, 6, xtr1
SETOPERAND popd_row, 7, xtr2
SETOPERAND popd_row, 8, target
SETOPERAND popd_row, 9, weight
Hopefully the code is self explanatory. You don’t need the intermediate variables such as surf, wave, ...etc., but I hope it helps with readability. GETTEXTFILE is the keyword you need to save the text-tab data of an analysis to a text-file. The string code for POP is Pop.
Assuming you have a settings file already, which you should for POPD, you can simply write:
GETTEXTFILE "C:\...\your_file.txt", Pop
Have a look at the Help File (F1) for GETTEXTFILE if you want to use a specific settings file.
@Asuku
popd_row = 1
INSERTMFO popd_row
surf = 1
wave = 3
field = 2
data = 1
xtr1 = 0.1
xtr2 = 0.1
target = 0.123
weight = 4.567
  • May 30, 2024
Thank you, @David.Nguyen
Example was helpful in achieving what I intended.
-AS
