Phase Mask
  • Sep 29, 2022 5:07 PM UTC
  • 1428 views
Madison
Is there a way to import an image into OpticStudio and have that incorporated into the light path? For example, I’d like to import an PNG file (Example: a white background with a black rectangular outline) and have light passing through it and observe the wavefront distortions that result. How can I do this?
Best answer by Mark.Nicholson
Hey Madison,
The Slide Surface in sequential mode and Slide Object in non-sequential mode will allow you to import a bitmap image and then pass rays through it. Note that it is the intensity of the rays that is modulated by the bitmap, not their phase.
  • Mark
Hey Madison,
  • Mark
Hi Madison,
We also have an option to convert an image into a grid phase surface:
brarnavreen
  • Sep 18, 2023 7:09 PM UTC
Hey Madison,
  • Mark
How to get the phase modulated then? Suppose i want to reconstruct a phase CGH by illuminating it with rays in zemax. can that be done?
  • Sep 19, 2023 2:22 AM UTC
@brarnavreen:
You should use POP to model diffraction from a CGH/DOE.  This post may be of some help:
