Optimization with Optically Fabricated Holograms (OFH)
  • May 3, 2023 8:13 PM UTC
  • 220 views
Michael.Young
I frequently encounter a problem when optimizing with the optically fabricated hologram (OFH) surface where the local optimizer or hammer optimizer will not close. I have to stop the OpticStudio process in the task manager and reopen the file. The hammer optimizer seems to be much more prone to this problem.
I will provide a toy file for examination shortly; however, I was wondering if this is a known bug or if there is a work around to prevent this behavior? I do call the HLGV operands and also the CMFV operands during optimization.
Best answer by Kevin Scales
Hi Michael,
Sometimes it happens in long optimizations that a request to terminate takes time to process. This is known to us. All I can say now is that if you wait it should stop eventually.
Kevin Scales
  • May 9, 2023 11:31 PM UTC
Hi Michael,
Michael.Young
  • May 30, 2023 10:03 PM UTC
Thanks Kevin,
It must take a really long time. For the time being, I limit the number of cycles, i.e., avoid the infinite option and that avoids the issue. Automatic will also work if using the hammer optimizer.
