optimization in nonsequential mode
  • July 16, 2021
  • 381 views
I want to design a collimating optic and I have a model of my extended source in nonsequential mode. When I optimize, the lens gets unreasonably thick. Is there a way to put a limit on this thickness in the nonsequential mode? I am familiar with how to do it in sequential mode, but I don't see the same features in the Optimization Wizard in nonsequential mode. Thanks!
Best answer by David
Hi Christy,
There is no entry for this in the wizard, probably because the parameters for non-sequential objects are so inconsistent. But if you look in the help system for the merit function editor you will find a category 'Constraints on Non-sequential Object Data.'  In there you will find many operands, including NPLT for Non-sequential Parameter Less Than. You can add these operands to the merit function generated by the wizard as needed.
  • 337 replies
  • July 16, 2021
Hi Christy,
