OpticStudio help documentation
  • November 18, 2025
  • 8 replies
  • 266 views
I don’t know about other users, but I find the new help system that requires an internet connection with login to an Ansys account to be rather annoying and less user friendly than the previous built-in CHM help file.
A while back, Tom posted a note that an option for accessing help files without needing an internet connection was in the works:
Just wondering if someone from Ansys can comment?
Best answer by Chris Normanshire
Hi ​@Jeff.Wilde ​@Sean Turner.
@Allie has just confirmed in her recent reply to Suspect Bug: Go To Surface | Zemax Community. That the offline help is scheduled to be included in OpticStudio 2026R1.
Sean Turner
  • November 18, 2025
I agree. The online help documentation is much slower to navigate than the local help document. Each time I want to step down a level in the navigation, the entire webpage has to refresh.
A few months ago, ​Allie mentioned a new approach similar to the old CHM file is in the works. I wonder how soon that might be implemented.
  • November 18, 2025
Yes, I hope a local help solution is re-implemented sooner rather than later.  I understand that Zemax probably had to adopt an Ansys practice when this change was made, but unfortunately in doing so they violated a basic axiom, namely: “If it ain’t broke, don’t fix it!”
Chris Normanshire
  • November 19, 2025
You’re not alone.
While it is not an actual solution - install an older version of Zemax to get the .chm help file. You can save the .chm file elsewhere if you want to remove the older version.
I find that an online help system is very slow too.
  • November 19, 2025
@Egis, Yes, on occasion I use a copy of the 2024 chm file, but of course the primary limitation is that there is no link to the 2025 GUI topical help (?) buttons.
  • March 19, 2026
Lifting up.
With 26 R1 - Does F1 work for you? It opens here but only one page is good “Ansys Help” how to use it. No Table of Contents nor search.
  • March 19, 2026
Lifting up.
Did Ansys release OpticStudio 2026 R1 ?
  • March 19, 2026
Yes, ZOS 26 R1 has been released, and it contains support for off-line help, similar to the older *.chm file version. Search capability is included.
Details are here:  Installing Off-Line Help for ZOS 26 R1
