OPEV issue with Reli
  • December 8, 2020
  • 106 views
Dear Sir,
I am trying to use OPEV to extract relative illumination
When I try to do this I just get an answer 1
See example below.
D=OCOD('RELI')    #
test=OPEV(D, pw, 11, 0, 0, 0, 0)
I can not work out why this does not work?
Please help
Berta.Bernad
Hi Matthew,
The syntax for RELI is
And the syntax for OPEV is
OPEV(code, int1, int2, data1, data2, data3, data4)
So int1 is the Sampling, int 2 the Wave, Data1 the Field, Data2 the Polarization, Data3 the target and Data4 the Weight.
It seems that in your example you are setting the field as 0, which doesn't exist. Also, you have to use double quotes (') instead of (').
I can extract relative illumination with something like this:
I hope it helps but let us know if not!
