off-axis parabolic mirror (NSC)
  • June 6, 2022
  • 1556 views
Nanday
I’d like to change a general spherical mirror into a off-axis parabolic mirror to avoid astigmatism.
In order to do this, I input ‘-1’ as conic 1 parameter as you can see following image.
But It doesn’t work at all….
Could you help what did I missed?
Best answer by Allie
Hi @Nanday
Looking at your file, I see the rays are striking your optic at the center of the optic, directly upon the local axis of the object:
Consider the sag profile of the Standard Lens type, as shown below:
If we plot this equation for k = 0 and k = -1, then we will see that for your aperture, the sag profiles are essentially the same:
It is only at large values of “r” that we start to see some deviation, as shown below here:
It is for this reason that an off-axis mirror is typically used at some point offset from the local axis origin.
In Sequential Mode, we can achieve this through the use of an aperture decenter and/or Coordinate Break surface, as is shown in the sample file C:\...\Zemax\Samples\Short course\Advanced Optical System Design Using OpticStudio\OAP_OSDUZ.zmx.
In Non-Sequential Mode, I would suggest switching to the Off-axis Mirror object type. This object type lets us define the surface sag, as well as the surface offset as discussed in the following forum post:
Try out that alternative object type and see if you can get the performance you’re after. Let us know if you have any other questions!
Allie
  • June 10, 2022
Hi @Nanday
Nanday
  • June 18, 2022
Thanks for the thoughtful reply.
As you said, I replaced it with an off-axis mirror.
Still could not overcome the problem of astigmatism.
Can you give me some hints to solve the astigmatism problem?
