NSC modelling deformed mirror
  • Jul 17, 2020 2:28 PM UTC
  • 162 views
Hi there,
I am thinking of modeling a specific deformation on a mirror in my set up to help develope a pass/fail criteria. I have an interferogram (Zygo image) but I cannot make it into a Zernike model (it is rectangular), I will have to estimate and approximate the shape of the mirror by the data given. Attached an example.
I can convert the profile cross-section (marked with red arrow) from fringes to microns, that should not be a problem.
My question is: what non sequential object would you recommend that I’ll use for the mirror?
Thanks!
Kevin Scales
  • Jul 17, 2020 10:28 PM UTC
Hi Ornit,
The attached files are not that easy for me to read or understand. But if I were to take a stab at answering this, I think my best best would be to go ahead and use your sag data to create a Grid Sag Lens. They can be rectangular and can take an arbitrary shape on the back surface. A Grid Sag Lens 2 will also work, though it supports front and back surface effects, which is more than you need here.
Kevin
  • Jul 17, 2020 10:50 PM UTC
Thank you Kevin!
I will try Grid Sag Lens.
Thanks
Ornit
