non-specular reflection
  • Feb 11, 2020 10:21 AM UTC
  • 227 views
I would like to model on non sequential mode an image reflected on a surface and study its shape and brightness from many angles. How could I do this?
Best answer by Thomas Magnac
You can do that in the non-sequential mode indeed.
Set up a source to shine on an object.
Set up the scattering properties of this object.
Add a detector to record the data and launch a raytrace.
Here is what it looks like in the sample file ''ABg scattering surface.zmx'' attached when you open a shaded model:
You can then change the angle of your source and run a raytrace again to analyse the pattern for different angles.
Here is an article describing the different scattering models in Zemax OpticStudio: https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01415
Finally, here is an article which shows how to add the surface properties to objects: https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01353
Thomas Magnac
  • Feb 11, 2020 2:03 PM UTC
