Non-Sequential Boolean Native/CAD not drawn
  • Dec 13, 2023 9:13 PM UTC
  • 430 views
I keep getting an issue where the Boolean Native/CAD disappear from NSC Shaded Model or NSC 3D Layout. I checked if they are being drawn, if the locations are proper and all the obvious stuff.
using version R2.01
Any one else encountering this issue?
Best answer by Kevin Scales
We have found some bugs associated with Boolean objects and will be investigating them further.
Kevin Scales
  • Jan 5, 2024 7:19 PM UTC
Andrew_Davies
I would suggest turning off the ACIS libraries as a trouble shooting step. This has solved a number of issues I have had with 3D objects failing to render correctly. Look for the setting check box that says "Use ACIS Libraries” and uncheck it.
Below is a form post that goes over it. Note that sometimes it’s called “Use Parasolid Libraries” instead of ACIS.
https://community.zemax.com/got-a-question-7/cylinder-2-volume-with-boolean-native-bug-4701?postid=15012#post15012
