multi-configuration breaks model
  • July 24, 2021
  • 41 views
When I try to make a multi-configuration model from a  single configuration model, it seems to not convert correctly. Other than going in manually to fix things, are there things to make this not happen?
Best answer by E. Robert.Ligon
My bad. Turned out none of the surfaces that were mirrors had their material columns filled out.
