Monte Carlo analysis of MTF
  • Nov 10, 2023 12:42 PM UTC
  • 496 views
When performing tolerancing on a system, ín particular a Monte Carlo analysis, the report provides a list of the criterium value (e.g. RMS spot radius) for each iteration. Recently ive come across a different type of analysis, where the full MTF function (for all defined fields) is drawn for each iteration, like in the figure below:
Can you elucidate how to execute this analysis?
Kind regards
Best answer by Andrey.Pravdivtsev
Create a MTF layout and use check bok “Overlay Monte Carlo Graphics” in Tolerance settings.
  • Visible
  • Nov 13, 2023 5:10 PM UTC
Thank you for the indication!
