Modelling vehicle headlight with asymetrical radiation pattern using Radiant source model
  • March 24, 2023
  • 113 views
Priscilla
Hi all,
Kindly assist on resolving this ,I'm simulating vehicle-to-vehicle (V2V) communication using a high beam headlamp model. Everything initially functioned as expected for clear weather, but now I am encountering a problem with the headlamp's radiation pattern, which causes it to go straight and miss both the target receiver and any objects in its path. I made unsuccessful attempts to troubleshoot the settings and recall the previous files. Any thoughts on what the root of this source's bad behavior might be would be greatly appreciated. I appreciate you .
Hi @Priscilla!
I was checking the forum and saw that this post was unanswered. Have you been able to solve your issue? If not would you be able to share more information? Thank you.
