hello,
I have a biconic surface I would like to perform an irregularity tolerance analysis on. I read about using TEZI. How can I use this for a biconic surface?
John
Best answer by Jeff.Wilde
View originalhello,
John
View originalYou could try using the composite surface capability: Introduction to Composite Surface
Thanks Jeff! I will look into this. Hope you are doing well!
John
Hi John. Yes, all is well; good to see you on the forum.
The relatively new composite surface looks interesting, especially for tolerancing. However, there is a note in the help documentation that indicates it doesn’t work for off-axis apertures, so it has some limitation.
An approach to tolerance off-axis surfaces is described here:
Tolerancing surface irregularity using a phase surface
