mixed NCS mode - Lenslet Array2 - POP
  • Oct 10, 2023 8:32 AM UTC
  • 351 views
Mich
I have an configuration of Lenslet array (Lenslet Array 2) in NSC Component in Seqential mode. I would like to see propagating beam on POP Display of 10x10 mm X,Y Width and sampling 1024px or more.
 Entrance Pupil Diameter is 10 mm, so from infinity arrive a ray buch impinging the NSC Component. This NSC component has 1 mm thickness. What shall I set for the Ref Object or the Inside Of parameters, and what shell I set  for Exit Loc Z and Back Propagation Distance in the Lens Data Editor, if I want see the matrix of focuses on the above meant POP Display? Thank you for advices. Michal
Best answer by Jeff.Wilde
@Mich:
The POP routine may likely not work properly in hybrid mode with an NSC lens array.
Instead, take a look at the “Lenslet Array.zmx” sample model provided with OpticStudio.  The lens array is modeled with a user-defined surface for use in a fully sequential model.
  • Oct 10, 2023 5:32 PM UTC
@Mich:
