Merit Function Editor: Control of ASP Coefficients
  • January 10, 2024
  • 239 views
James
Merit Function Editor:  Control of ASP Coefficients:
Are there operands to directly control , or write expressions for the aspheric terms ?   For example if one is using an Even Asphere, and you wish to reduce the 4th order term, (Par 2), how would one do that ?
Best answer by aalim
you can use PMLT/PMGT/PMVA
  • January 11, 2024
