Machine half diameter is gray can not edit, how to solve
  • 19 November 2021
  • 71 views
Hello everyone !
After I finished the design with OpticStudio, I wanted to leave some allowance for seci diameter, but I found that the column of mechanical seci diameter was gray and could not be edited. May I ask how to solve this situation?
thanks !
like this:
icon
Best answer by Andrey.Pravdivtsev 22 November 2021, 10:42
Userlevel 3
Badge
What type of license do you have? If I correct it works for Professional and Premium only.
Userlevel 3
Badge +1
Hi
Yes~ Andrey is correct. It should be caused by the license version. Chip Zone and Mechanical Semi-Diameter. Both parameters are available in the Professional and Premium editions only.
Sean
Thank you for your help. It seems to be the software version.
