Lensarray on sperical surface
  • August 30, 2022
  • 157 views
Is there any way to model a lensarry onto a spherical surface?
Example see below
Hi Sepp,
Strictly speaking, if you have a mathematical expression for how the lenslets are distributed on the spherical surface, which isn’t obvious at all, you could use the ZOS-API or a macro to create the lenslets and position them accordingly. You could use spherical coordinates to locate the lenslet, but the question becomes: how to pick the sampling rate?
I made a simple dummy example:
import numpy as np
# Number of samples for theta and phi
samp_t = 6
samp_p = 15
# Samples of theta and phi (using the physics convention: ISO 80000-2:2019 from Wikipedia on Spherical Coordinate System)
theta_space = np.linspace(0, np.pi/8, samp_t)
phi_space = np.linspace(0, 2*np.pi, samp_p, endpoint=False)
# Spherical surface radius
major_radius = 5.0
# Standard lens type (used later in the loop)
std_lens_type = TheSystem.NCE.GetObjectAt(1).GetObjectTypeSettings(ZOSAPI.Editors.NCE.ObjectType.StandardLens)
# Default direction cosine for new objects stored as Vector A (used later in the loop)
a_vec = np.array([0.0, 0.0, 1.0])
# Loop over theta and phi
for theta in theta_space:
for phi in phi_space:
# Calculate lenslet coordinates XYZ
x_pos = major_radius * np.cos(phi) * np.sin(theta)
y_pos = major_radius * np.sin(phi) * np.sin(theta)
z_pos = major_radius * np.cos(theta)
# Create new object (lenslet)
lenslet = TheSystem.NCE.InsertNewObjectAt(1)
# Change new object type to Standard Lens
lenslet.ChangeType(std_lens_type)
# Update new object XYZ position
lenslet.XPosition = x_pos
lenslet.YPosition = y_pos
lenslet.ZPosition = z_pos
# Update lenslet radius
lenslet.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par6).DoubleValue = -2.0
# There should only be a single lens at theta = 0.0 degree and it doesn't need a change of orientation
if theta == 0.0:
break
# Calculate direction cosine of the normal to the spherical surface at the XYZ coordinates
l_cos = x_pos / major_radius
m_cos = y_pos / major_radius
n_cos = z_pos / major_radius
norm = ( l_cos**2 + m_cos**2 + n_cos**2 )**0.5
l_cos /= norm
m_cos /= norm
n_cos /= norm
# The normal direction cosine is stored as Vector B
b_vec = np.array([l_cos, m_cos, n_cos])
# Using this thread: https://math.stackexchange.com/questions/180418/calculate-rotation-matrix-to-align-vector-a-to-vector-b-in-3d
# One can find the rotation matrix that aligns Vector A to Vector B
v_vec = np.cross(a_vec, b_vec)
c_val = np.dot(a_vec, b_vec)
v_x = np.array([[0.0, -v_vec[2], v_vec[1]], [v_vec[2], 0.0, -v_vec[0]], [-v_vec[1], v_vec[0], 0.0]])
# This is the rotation matrix
r_mat = np.identity(3) + v_x + np.dot(v_x, v_x) / ( 1 + c_val )
# Using this method: http://eecs.qmul.ac.uk/~gslabaugh/publications/euler.pdf
# One can decompose the rotation matrix into three rotations along the cardinal axes
# In our case, it is a little bit easier because the rotation about Z is the identity
# matrix (the lenslets are rotationally symmetric in this simple example).
# There is still an ambiguity (the rotation angle is an arccos of a matrix coefficient,
# therefore there is the plus and minus solutions that are valid), which is solved by
# looking at the lens XYZ coordinates
if x_pos < 0:
tay = -np.arccos( r_mat[0, 0] ) / np.pi * 180
else:
tay = np.arccos( r_mat[0, 0] ) / np.pi * 180
if y_pos > 0:
tax = -np.arccos( r_mat[1, 1] ) / np.pi * 180
else:
tax = np.arccos( r_mat[1, 1] ) / np.pi * 180
# Update the lenslet orientation
lenslet.TiltAboutX = tax
lenslet.TiltAboutY = tay
Which gives the following result:
As you can see, using a uniform sampling leads to lenslet of different sizes and I don’t know how to solve that issue for your specific problem.
Alternatively, this array can probably be generated in a CAD software, and OpticStudio is able to import most of the CAD file formats.
Lastly, it might be worth clarifying what you are trying to achieve with this model. Can you consider a single lenslet at first? Are you interested in diffraction effects from the array?
  • 1159 replies
  • August 31, 2022
Hi Sepp,
import numpy as np
samp_t = 6
samp_p = 15
major_radius = 5.0
if theta == 0.0:
break
l_cos /= norm
m_cos /= norm
n_cos /= norm
if x_pos < 0:
else:
if y_pos > 0:
else:
  • September 1, 2022
Thanks for your replay. At least it seems, there is no easy way to do so. As I have good access to CAD capacities, I probably will generate the parts on a CAD, as you mentioned
Sepp
  • 1159 replies
  • September 1, 2022
Hi Sepp,
I think it might be better indeed. Specially if you’re only analyzing this model (and not trying to optimize its parameters).
However, I guess you’ll still be faced with this non-trivial issue of how to distribute the lenslet on the spherical surface (perhaps this can help). Let us know if and how you manage to implement this model :)
