ISO 10110 drawing: Specifying tolerance parameter in % units and not in mm
  • Jun 13, 2022 5:06 PM UTC
  • 229 views
Is there a way to specify the following in the ISO element drawing tool:
  1. Vd in %
  2. Radius in %
Thanks
Best answer by Jeff.Wilde
If you use the Tolerance Data Editor Wizard, then you can supply percent tolerance values for radius and Vd.
The percentages are converted into corresponding tolerance values that can subsequently be displayed on the ISO Element print.  I don’t think there is a way to have OpticStudio create tolerance values on the prints that are the % values themselves.
  • Jun 14, 2022 5:56 AM UTC
