I'm quite new to ZOS and I use the version 15 (yes, I know it's 5 years old but the upgrade is quite painful in my company).
I wonder if I can find anywhere a synthetic log file with informations like the number of rays which where traced, the various non-blocking errors (such as geometric errors), the duration of the simulation, the amount of memory used and the like. Something like what I get with the Prescription Data button but with outpu data and not input data.
Regards
Hi Christophe,
We do have an error listing with errors and memory usage here under Setup>System Check:
However it does not give the number of rays or duration of raytrace.
Hope this will help!
That helps a lot. Thanks.
