Is it possible to define multiple objects to follow the same operands in the Merit Function Editor?
  • November 14, 2021
  • 167 views
Hi, I am using the NPXL operand since I don’t want all my object positions to exceed the value I set. However,  I have quite a lot of objects (Around 100), it is possible to not manually define for each object and instead apply it for all the objects simultaneously. (I.e each NPXL operand I have to change the Object Column value)
Thanks for the guidance. Greatly appreciated!
Hi Kai,
Unfortunately, you cannot do that with a single NPXL operand. However, you can create a macro to automatize the work.
Macros are relatively simple pieces of code written in an almost human readable format that can perform routine tasks automatically.
I would advise to read this article to get more familiar with macros, and then try to have a look at this thread and see if you can write your macro yourself.
I’m happy to help you along the way should you have any question.
  • 1159 replies
  • November 14, 2021
Hi Kai,
  • 6 replies
  • November 15, 2021
Thanks once again!
