Infrared system setting
  • April 20, 2021
  • 287 views
HI guys. Have a good day.
I am making a simple system for infrared. I wonder if Zemax has Infrared Image simulation or not?.  Although I adjusted the wavelength and temperature, the image simulation seem like the visible image. So how can i fix this and is there any IR material catalog in Zemax ?  Thanks in advance.
Best answer by Katsumoto Ikeda
Hi Hieu, Image Simulation has a separate Wavelength setting, it is RGB by default. Try opening 'Settings' and looking at the Wavelength, and change it to '1+2+3'.
I hope this helps.
-Kats
Katsumoto Ikeda
I hope this helps.
-Kats
