Importing freeform surface profile - Spherical coordinates parameterization
  • Mar 4, 2024 2:57 PM UTC
  • 194 views
CJ27
Hello again Zemax community,
I am trying to import a freeform surface into Zemax but I am experiencing the following difficulties:
My freeform surfaces are externally generated and these are constructed by parameterizing the surface by the distance from the origin the points on the surface. As a consequence, this can result in surface profiles which do not have a single height value for a given x and y coordinate. You can take a look to an example of the type of freeform surface that I am generating:
One way in which you can think of this surface is as a spherical base surface for which at each point, there exists a radial offset from the ideal spherical base.
After externally generating my freeform surface, I tried importing it into Zemax by using a .DAT (for sequential analysis) and a .GRD (non-sequential analysis) file.
However, once I take a look to the sag profile using the Surface sag tool, I can clearly notice that the lower surface profile is lost. To me it seems that in this case the surface can just have a single height value for a given x and y coordinate.
Do you have any recommendation on what to do in this situation? Do I maybe need to use a different approach for importing this surface profile into Zemax?
In advance, thanks for the help and the comments!
A sequential surface will not support two intersection points, but a non-sequential object should.
CJ27
  • Mar 5, 2024 7:32 AM UTC
Hi @Mark.Nicholson , thanks for the feedback.
Do you know if I should use the .GRD file format to specify the surface profile? As far as I could see, there was no difference between a .DAT file and a .GRD file and at least in the .DAT format, you just specify the spacing along x and y and the direct surface height profile information without any explicit information on the relationship between the coordinates.
Should I maybe use a different file format?
