How to specify TIND and TABB in ZOS-API without using Tolerance Wizard?
  • October 15, 2022
  • 135 views
I am developing a custom tolerancing script using ZOS-API. I would like to perturb the Index of refraction and Abbe values within a certain range. How can I do that in Python ZOS commands? I could not find any reference to it in the ZOS syntax help documentation.
Thanks - A
Hi @Asuku !
Our built-in tolerancing tool adds an offset solve to the materials when tolerancing:
I think you can use the same technique for your custom tolerancing.
Let us know if this helps.
Hi @Asuku !
