How to retrieve data from NSDD operand
  • December 2, 2021
  • 1046 views
Hello! I am trying to retrieve the standard deviation value from a detector viewer via the use of a NSDD operand #Pix -4 . How might I do so?
Thanks.
Hi Kai,
The Help File about NSDD can be found under The Optimize Tab (sequential ui mode) > Automatic Optimization Group > Merit Function Editor (automatic optimization group) > Optimization Operands by Category > Non-sequential Ray Tracing and Detector Operands.
In short, prior to calling any subsequent NSDD operand, you need a call to a NSDD which clears all detectors. Since all detectors need to be cleared, you also need to run a raytrace. In your Merit Function you should have:
  1. NSDD to clear all detectors
  2. NSTR to run a raytrace
  3. NSDD to retrive detector values/metrics
I’ve shown an example in the screenshot below:
For the standard deviation you need to specify the Det#, 2 in my case, the Pix#, -4 as you mentioned, and the Data is 0 for flux, 1 for flux/area, 2 for flux/solid angle pixel, 3 for normalized flux, 4 for absorbed flux, and 5 for absorbed flux/area.
Does that make sense?
Hi Kai,
Hello David, thanks for helping me out once again!
