How to generate 10 waves of spherical aberration
  • March 12, 2021
  • 359 views
I want to generate spherical aberrations in lens system, without inducing other aberrations (as small as possible is ok).
Is there an operand in merit funcion that I can use? Thanks a lot.
Best answer by Mark.Nicholson
Place a surface at a pupil plane and make it an Irregular surface. You can then set spherical directly. See the docs for the Irregular surface, I htink it takes lens units as argument so you'll need to work out the lens units needed for your 10 waves.
- M
- M
