How to do an image simulation of line-scan sensor in zemax to get an area sensor alike image?
  • October 27, 2023
  • 296 views
Yang.Yongtao
Hi zemaxers
 I am trying to do a line scan optical system image simulation.
And the first thing I thought is multi-configuration. It makes different layouts to show as one visually, but I am wondering is it possible to show different image surfaces to show as one in sequential mode or different detectors as one in non-sequential mode? I checked the zemax help but did not find the solution.
Could you kindly give me some advice on it ?
Thanks
Yang
Best answer by Mark.Nicholson
Hi Yongtao,
You can certainly use multi-configurations, but if you want high resolution you may need a LOT of configurations and that gets cumbersome. It might be easier to just do the loop within a macro or ZOS-API, so you
position the object
trace rays
get the line image
and then just loop over the possible object positions with whatever step size you want.
  • Mark
Hi Yongtao,
position the object
trace rays
get the line image
  • Mark
Yang.Yongtao
  • October 30, 2023
Hi Mark
 Thank you for your advice! I would like to try it.
Best Regards
Yang
