How to do a Slide Object image simulation in Non-sequential
  • Oct 25, 2023 4:07 AM UTC
  • 1266 views
Yang.Yongtao
Hi Zemaxers
I am learning to do an image simulation in non-sequential mode.
but not sure whether I am right, could you give me some advice?
what I did
1) set the slide object after the source
2) use detector rectangle to analysis
3) ray tracing
3) show the radiant intensity in detector viewer
My question
1) is the step above all right?
2) the result the detector viewer shows includes aberrations?
Thank you in advance!
Best answer by Oran
This is pretty much OK, except I see only parallel rays from your source, try using Source Diode for example to add angles according to your NA
  1. The steps are OK
  2. You should be able to see aberations
  • Visible
  • Oct 25, 2023 6:04 AM UTC
  1. The steps are OK
Yang.Yongtao
  • Oct 26, 2023 11:27 PM UTC
Oran Thank you!
