how to define object size in mix mode
  • February 17, 2022
  • 352 views
I am setting up a seq and non-seq mix mode, and using Prism45.POB as object for non-sequential component.
it requests prism45 to be 8mm, I don’t know where I can input to set up this specific size.
Thanks in advance.
Ying
Hi Ying,
Unless I have missunderstood the question, the way you scale a Polygon Object isn’t different whether you are in mixed- or pure non-sequential mode.
A Polygon Object is defined by its vertices that are describe in the *.POB file. If you open the Prism45.POB file with a text editor, this is what it reads:
! A 45-45-90 prism with no mirror side
! FSI Dec 18, 1998
C 1 "Splitter surface"
! front face vertices
V 1 -1 -1 0
V 2  1 -1 0
V 3  1  1 0
V 4 -1  1 0
! back face vertices
V 5 -1  1 2
V 6  1  1 2
! Front face rectangle
R 1 2 3 4 0 0
! Top face rectangle
R 4 3 6 5 0 0
! Bottom rectangle
R 1 2 6 5 0 1
! left side triangle
T 1 4 5 0 0
! right side triangle
T 3 2 6 0 0
The syntax used in this file is documented in the Help File under:
The Setup Tab > Editors Group (Setup Tab) > Non-sequential Component Editor > Non-sequential Geometry Objects > Polygon Object
Briefly, you can view from the front face vertices that the front face is a rectangle whose corners are (-1, -1), (1, -1), (1, 1), and (-1, 1) in X and Y (column 3 and 4). It is a 2 x 2 rectangle aligned with X and Y.
The only size you can change in a Polygon Object is the scaling and it applies to all dimensions. If you want the front face to become 8 x 8, you need to change the Scale parameter of the Polygon Object in the Non-Sequential Component Editor to 4.
Let me know if this answers your question, and take care,
  • 1098 replies
  • February 18, 2022
Hi Ying,
! FSI Dec 18, 1998
V 1 -1 -1 0
V 2  1 -1 0
V 3  1  1 0
V 4 -1  1 0
V 5 -1  1 2
V 6  1  1 2
R 1 2 3 4 0 0
R 4 3 6 5 0 0
! Bottom rectangle
R 1 2 6 5 0 1
T 1 4 5 0 0
T 3 2 6 0 0
  • 5 replies
  • February 18, 2022
Hi David,
Thanks for your reply. Now I understand how to use “scale” in the parameters of Polygon Object.
Ying
  • 5 replies
  • February 27, 2022
Hi David,
Here  is a dumb question: when we start a non-sequential mode design, how to decide the layout with all the elements? Do we need to discuss it with mechanical engineer about all the space dimensions first?
Ying
