How to create a combined prism in NSC
Christabelle Tiong
Hi, I am very new to ZEMAX, may I know how can I build a combined polygon in ZEMAX in NSC mode?
For example, I need a combination of two types of material. The 1 and 3 sections use the same material but with different dimension, the second section uses another type of material.
Best answer by Jeff.Wilde
@Christabelle Tiong :  see attached.
Yang.Yongtao
Hi Tiong,
 I am also trying to use the polygon in Zemax NSC mode, but I guess, if the parts are combined together, material will always be same
 if it were me, I would create the 3D data using a CAD software (solidworks or creo)and then use a  CAD part object in Zemax.
 best regards
yang
Mike.Jones
Also, look up the NSC object "Polygon Object".  You can define each subsection in  POB files, assign its facets properties (transparent, reflective or absorbing), assign optical coatings to each non-absorbing facet, and assign the bulk material.  Adjacent POBs can be different materials, but if you're doing thermal analysis, adjacent POBs may have different CTEs and will either shrink away from each other, or expand into each other. Either case can reduce accuracy of raytracing results.   I've done hundreds of POBs with good results.  And yes, defining in CAD is the other good method.
Christabelle Tiong
Hi, thanks so much for the reply.
Do you guys have any example files that I can look at to understand more.
You can also use the nesting rules with native objects to construct more complicated structures.  See the help documentation:
To create the three-piece object in the original question, you can use two rectangular volumes having the first material for sections #1 & #3 (these volumes are separate and don’t overlap with one another), then following these two objects you insert a polygon object (or another rectangular volume with tilted end faces) with the exact shape and material that you want for the middle section #2.  It overlaps with the first two objects, but since it follows them in the NSC Editor, its properties will be used for ray tracing, replacing those of the first two objects where ever they intersect.
Christabelle Tiong
Hi Jeff,
Could I have the ZEMAX file on the build in the picture
  • March 1, 2023
