How diffraction ray-tracing is calculated
  • June 11, 2020
  • 1935 views
Michael Cheng
That's try to check math/eqaution details about how diffraction is calculated for ray-tracing.
Here is some key points for taking back:
  • The ray-tracing eqaution for grating and any phase profile are same.
    • They are all based on the principle that projected wave vector should be continuous at material boundaries.
  • The word 'conical diffraction' is explained.
  • The 'phase' in OpticStudio mainly describes 'periodicity'.
  • These diffraction calculation supports multiple-wavelength
    • This is true for all diffractive surfaces like: Binary 2, Zernike Standard Phase, Grid Phase, Diffraction Grating, Elliptical Grating, ... etc.
    • For Physical Optics Propagaion (POP) and metalens, the support to multi-wavelength for phase surfaces may be no longer true, but we don't discuss much here.
We have a perpetual educational license. I wonder if you can suggest some example to set up a simulation for variable-length grating?
My grating is 2D structure and looks like a continuous bar, and I am interested to see the first few diffraction orders of diffraction at three wavelengths (RGB). Any good examples to starts with?
