How can I model a cone in non-sequential?
  • 3 July 2020
  • 121 views
Userlevel 3
Badge +2
This can be done with the Elliptical Volume object, setting either the Front R or Back R to be a really small value (1E-6). Or you can also use Part-Designer; you just need to use one of the pre-defined shapes and save it as a .ZPO object:
Once done, you can import this object in the Non-Sequential Component Editor, and apply different properties or coatings to its faces:
Be the first to reply!
