Help in conversion from .ZRD to .txt
Nicola Nicassio
Hi, I would like to ask you a favour for the conversion of a .ZRD file to a simple .txt file.
I know how to perform this operation, but this days I’m out and I can’t use my PC with Zemax installed on.
Therefore, I’m not able to open .ZRD files at the moment.
Could you please perform this operation for me?
Here I attach both the ZRD file I need to be converted and a sample of the output I want to obtain ( the structure is important since I have written an analysis code to process this kind of data).
The desired output (30 rays if I remember well) should be obtained by checking the option “Path” when opening the file using “Ray Database Viewer”
Thanks in advance.
Hi Nicola,
Let me know if that’s what you expected.
  • 1148 replies
  • August 23, 2022
Hi Nicola,
Nicola Nicassio
Thanks for the quick response, that’s exactly what I expected.
