Groove frequency
  • August 20, 2020
  • 123 views
Dear Optical Engineer,
I am modeling a very large Fresnel lens based on your model sample Fresnel 1.  I set the lens unit to meter and I would like to have 100 grooves per meter. Can I set the +depth/-Frequency parameter to -100?
Thank you,
Abou.
Best answer by Kaleb
Hi Abou,
Yes, you are correct. If you set your +Depth/-Frequency to -100, it will yield 100 grooves per radial lens unit. In this case the lens unit is meters, so it will correspond to 100 grooves per meter.
-Kaleb
  • August 20, 2020
Hi Abou,
-Kaleb
