Get the maximum ray angle impinging onto the image plane in sequential mode
  • January 23, 2024
  • 570 views
Is there an operand to get the maximum ray angle impinging onto the image plane (relative to surface normal) in sequential mode ?
I know about the operands listed in help section Constraints on Real Ray Data, but they require setting normalized pupil coordinates Px/Py first.
Marko
Best answer by Sean Turner
The merit function operand MXAI uses field number, not Px and Py.
From help file:
Maximum angle of incidence. This boundary operand traces the marginal and chief rays from defined Field and reports the maximum angle at the surface defined by Surf. See MNAI for more details about the input parameters.
However, if there is a ray somewhere else in the pupil with AOI larger than one of the marginal or chief rays available with this operand, you may need an alternate approach. For instance, you could use a ZPL macro to loop through a grid of Px and Py values and calculate the RAID operand. Here is a simple bit of code that would do it. This uses a 101 x 101 grid of pupil coordinates, but you can adjust accordingly. Also, the normalized field coordinates Hx, Hy are both set to 0 so this only evaluates a single field. You can add another 2 layers of FOR loops to iterate through Hx and Hy values as well, but this should get you started.
C = OCOD("RAID")
FOR i, 1, 101, 1
    PX = (i-1)/50-1
    FOR j, 1, 101, 1
        PY = (j-1)/50-1
        AOI = OPEV(C, 0, 1, 0, 0, PX, PY)
        PRINT PX, $TAB(), PY, $TAB(), AOI
    NEXT
NEXT
Edited to add: normalized pupil and field coordinates should really be accessible as independent variables in universal plots.
Sean Turner
  • January 23, 2024
From help file:
C = OCOD("RAID")
FOR i, 1, 101, 1
    PX = (i-1)/50-1
    FOR j, 1, 101, 1
        PY = (j-1)/50-1
    NEXT
NEXT
  • January 25, 2024
Hello Sean,
Yes, in my case I do not know for which pupil coordinates the angle on the image surface will have maximum value, and was thinking maybe there is an operand for thath. I have used Matlab ZOS API, since I am more familiar with it than ZPL. I have only looped over Px, Py/Hx/Hy are all set to zero.
TheMFE = TheSystem.MFE;
Operand = ZOSAPI.Editors.MFE.MeritOperandType.RAID;
n = 101; srf = 4;
px = linspace(0,1,n);
val = zeros(1,n);
for i=1:n
val(i)=TheMFE.GetOperandValue(Operand,srf,1,0.0,0.0,px(i),0.0,0.0,0.0);
end
plot(px,val);xlabel('Px');ylabel('Value');grid
The plot looks good to me for estimating the maximum RAID operand value. Thank you for the idea.
Marko
