fiber optic focalization
  • Jan 19, 2022 8:37 PM UTC
  • 636 views
Jildy
I'm very new on Zemax... (just a few exercises and tutorials)
I am struggling with the simulation of an optics for a time-of-flight system.
I have an optical fiber with 105 um 0.22 NA core and I have to focus it in the best possible way at a distance of 20 m (now I set 200 mm, to test if the optimization works). In the end my purpose is to compare the results obtained using a commercial fiber optic collimator and a custom one, but I'm not able to optimize any distance or curvature.
I think I'm getting the merit function wrong / not inserting the right operand or constraints...
Can you help me? I attach a screenshot of what I have now.
Hello Jildy
I have attached an example of a starting point.
For your optimization, I have set up a merit function for the smallest spot for each field but maybe you are looking at the smallest overall spot. Have a look at our free tutorials if you are quite new to the software as it shows how to set up the optimization: https://www.zemax.com/blogs/free-tutorials/imaging-system-fundamentals
How to design a singlet lens, Part 3: Optimization
Let us know if that helps.
Hi Jildy
I think I would change the definition of your input. Since you want to focus the fiber, I would define the System Explorer...Aperture using an object space NA and then the core can be modelled as different field points (for example 2 or 3 to start with). You can maybe tick Telecentric Object Space. It will make each field ray parallel to the optical axis.
The software will then be able to optimize to image the fiber.
Jildy
  • Student
  • Jan 26, 2022 3:27 PM UTC
Dear Sandrine,
thank you for your reply.
I don't understand... I tried to use Aperture Type: Object Space NA, but nothing changes.
Why telecentric object space? I want the entrance pupil to be the optical fiber, that is my source (fiber coupled laser diode).
Is there a list of operands to be included in the merit function with their meaning? I don't know how to tell it to optimize in order to have the smallest possible image.
Regards
Hello Jildy
