When I pick an intermediate surface in FFT MTF, OpticStudio doesn’t evaluate the MTF there. It adds a paraxial marginal ray height solve and computes it at the paraxial focus of that surface instead.
I know this is documented in UserGuide 3.2.1.2, “Evaluating results at intermediate surfaces.” The problem is that nothing in the analysis window tells you it’s happening. Judging by the forum, I’m not the only one caught out by it:
- https://community.zemax.com/got-a-question-7/different-psf-results-for-same-position-planes-977
- https://community.zemax.com/got-a-question-7/diffraction-enclosed-energy-out-of-focus-1940
- https://community.zemax.com/got-a-question-7/wavefront-change-at-image-plane-and-just-before-image-plane-5373
If I select a plane, I expect the result at that plane. If it can’t be computed there, I’d rather get a “cannot analyze at this surface” message than a result from somewhere else. As an alternative, any of these would help:
- a “refocus to paraxial focus” on/off option
- a line in the analysis text and title showing the plane actually used and its offset from the selected surface
For now I’m working around it by truncating a copy of the system so my plane becomes the image. But this is very uncomfortable for quick analyses on systems with multiple intermediate image planes.
