Exit port
  • December 8, 2020
  • 100 views
Hi all,
I am using a paralleloid for non sequential ray tracing.
Even through it's not my first time using mixed mode, I have a problem to understand why the rays terminate and do not propagate
after the exit port (surafce no. 6).
p.s
The actual system is much more complicated, so non sequential ray tracing must be used.
Nadav
Best answer by Kevin Scales
Hi Nadav,
It looks like you have a very small Clear Semidiameter for your exit port, but with a larger surface aperture. For exit ports, the semi-diameter determines the port diameter, though you can use the surface aperture to further constrict and shape the port. If you expand your semi-diameter to something large like 100, you seem to be fine.
Kevin
  • December 8, 2020
Here the zmx file.
The previous messgae had the polygon file.
Kevin Scales
Hi Nadav,
Kevin
  • December 8, 2020
Hi Kevin,
it's wprkimg good now.
Thanks for the quick reply.
Best regrads,
Nadav
