Divergence Angle in POP
  • February 8, 2022
  • 897 views
Dear Experts,
in order to get an exact understanding of POP, I have stripped down a simulation to purely a POP simulation, i.e. without any optical element but a free-space propagation (Gaussian beam diffraction) over 1000m:
My  beam definition is
My beam waist is 21mm. Exploring that with the Beam File Viewer, this is a 21mm radius at 1/e². However, in the help file I find
where w_0y (omega) should be the same as Waist X?! According to these formulas this would be a 1/e radius (not squared), if I do the math right. Maybe w_0y is not equal to Waist X?
According to Teich/Saleh a 21mm 1/e² radius Gaussian beam should result in a divergence theta of (omega_0 is the 1/e² radius)
i.e. my beam should have a radius of 23.5mm after 1000m propagation.
Reading from the cross section in the image plane, I get around 31mm at 1/e², so a difference of 7.5mm to the expected 23.5mm.
It would be great to get a hint, if my modelling of such a minimal system, i.e. only the Gaussian beam diffraction, is correctly done in Zemax. I attach my file.
Many thanks. Any advice would be very welcome
Markus
Best answer by Jeff.Wilde
Hi Markus,
Simply using the far-field divergence angle to estimate beam radius, when measured from the waist location, is an over-simplification.  The actual dependence is slightly more involved (see the Wikipedia page on the properties of a Gaussian Beam, or any reference on Gaussian beams):
Using this formula for your example yields a beam radius of 31.5 mm at z = 1000 m.  Another way to check your results is to use the Paraxial Gaussian Beam Data analysis function:
  • February 8, 2022
Hi Markus,
  • February 10, 2022
Jeff, thank you so much for your support! I gained some good insight into POP and improved my understanding of Gaussian beams :)
Markus
