Detector Viewer NSC Shaded Model Not Displaying
  • October 20, 2022
  • 280 views
In NSC Shaded Model I want to colour pixels by last analysis. I have a simple model with a couple of detectors; they both display the correct profile in the detector viewer but in NSC Shaded Model only one detector shows the plot. As per below - one detector shows fine ( the source array ) but then the other one ( the big black square ) doesn’t show the irradiance in the NSC Model but its fine in the detector viewer.
As far as I can see the settings for both detectors are the same ( acceptance angle etc ).  I’ve seen this before and obviously missing something but what . . .
The big black square should show this . . . ( which is displaying fine in detector viewer )
Best answer by Michael.Lovelady
My bad; I’d exceed the maximum pixel value ( 1,200,000 ) for the detectors on the NSC view
Berta.Bernad
  • 112 replies
  • October 27, 2022
Hi Michael,
Yes, as you have found out, when rendering NSC detector objects with more than 1,200,000 pixels will not show individual data for each pixel to keep the total amount of required computer memory reasonable.
