Detector viewer in zemax macro
  • 6 December 2019
  • 210 views
Dear all,
I'm in problems with using zemax macro in NSQ mode.
I want to:
1. open the detector viewer with the zemax macro.
2. save/export image and text data(not ray data!) of the detector viewer with the zemax macro.
Could someone please help me or give some macro codes for these problems?
Thanks.
Userlevel 3
Badge +1
EXPORTBMP will let you save the image from the detector.
GETTEXTFILE lets you save the text data from the detector viewer window.
I hope this helps.
Sean
Userlevel 7
Badge +3
SAVEDETECTOR will also save the data in a detector (not the ray trace data, that's held in a .ZRD file). It and LOADDETECOR perform the same functions as you get under Detector Tools in the UI
Thank you all!
Bless you.
