Delimit the variation of variables in the NSC optimization.
  • June 15, 2022
  • 323 views
Luca.cellerino
Hello everyone, in a backlight project of an LCD screen with backlit lighting I would like to use the optimization function by assigning a variable to the x and y positions of each source (6 sources) and I would like to define the max variation range for each variable.
It's possible?
Thanks to all.
Best answer by Ray
Hi Luca,
You can use the NP*G & NP*L operands (* stands for X, Y and Z) in the merit function to set the lower and upper bounds respectively. If you want to also drive them towards a preferred position, use NP*V.
  • June 15, 2022
Hi Luca,
