Custom spectrum in 'Phosphors and Fluorescence'
  • Jan 26, 2023 2:30 PM UTC
  • 197 views
Josh135346
I created some absorption and emission spectra using the ‘Create Spectrum File’ button in the libraries tab. They both plot fine, they are simple flat spectra. However, in the ‘Volume Physics’ section of the non-sequential component editor these spectra do not appear in the list of files in their respective drop downs. Initially only one of them did, then I restarted OpticStudio and it then didn’t appear anymore.
Cheers,
Josh
lionheartsummit
Hello Sir,
Have you solved your problem? Because Im having the same issue right now. If yes, could you please explain it to me?
