Complex Prism Creation
  • Nov 13, 2022 9:46 PM UTC
  • 552 views
Michaelkm8
           I am curious what the best way to create a multi faceted prism is in Zemax.  I have tried using multiple surfaces (freeform, various rectangle volumes, triangles, etc...), but I do not have the freedom that I need to make it customized.  I want to make a prism with 4 or more faces and design it similar to the freeform surface where I define it one point (face) at a time.  It would be great if there was a surface defined by angles and distances.  Can someone point me to the right surface for this?  I can figure out the rest once I know where I need to start.  Thanks.
Best answer by David
It’s a bit cumbersome compared to CAD programs, but OpticStudio allows complex polygon objects to be created by means of a text file. See Creating Polygon Objects in OpticStudio.
You could also generate an object in another CAD program and import it.
  • Nov 14, 2022 12:38 AM UTC
Michaelkm8
  • Nov 14, 2022 1:13 AM UTC
Thanks for the help David.  With respect to TIR, absorption, and dispersion if I imported a CAD file and told Zemax it was a volume of BK7 would there be any issues that may arise since it is not a standard Zemax surface/object?
Thanks again.
  • Nov 14, 2022 1:28 AM UTC
The only issue I know of is that imported cad parts can be slower to ray trace than native parts. I avoid them when I can in favor of Boolean combinations of native components. But there have been improvements in these areas so my experience may be dated.
