Collimating beams with lightpath lenses
  • Nov 12, 2024 11:20 AM UTC
  • 145 views
Frantisek
I would like to ask you to help with one Zemax file.
I use one Lightpath aspheric lens to collimate beam in 30 mm distance.
In POP there is some Newtons circles as picture of irradiance
In don’t know, why there is no standard Gaussian distribution of beam. It is looks like some interference of sources……
Is it possible, that in lens model is EVEN ASPHERE used ?
Or there is some bad settings somewhere ?
POP picture, setting and lens data of the lens are in files.
Thanks for any answer
Best Regards
Frantisek
  • Nov 19, 2024 2:51 PM UTC
What is yous system? The beam profile is at Surface 18.
Reduce to only 4 surfaces - object, 2 for lenses, and image.
