A colleague converted a CodeV file to a Zemax file. I am a Zemax user, the file won’t trace rays in Zemax . I get an error statement - “error in target, can’t lunch rays”. I went ahead to set vignetting in the field editor and try to trace rays again and now I get the statement - “error in target, missed surface 52”.
since rays can’t be traced, no analysis can be done. What can I do to fix these errors? could this be a conversion problem from CodeV to Zemax ?
Assuming the problem is from the conversion, how do I fix this?
Thank you.
