Can use GENC at the surface other than image surface?
  • Oct 30, 2024 7:51 PM UTC
  • 113 views
jiangmin
I would like to use GENC to find the GEO radius. it seems I can only get that data at the default surface-image surface. How can I get that data in other surfaces, such as the surfaces close to image surface?
  • Oct 30, 2024 11:59 PM UTC
You can use IMSF before the GENC operand.  If you want the geometric radius from the Spot Diagram, you can also look at RSCE, RSCH, RSRE, and RSRH.
