CAD Part Zemax Part Designer
Attempting to load a CAD file created from Part Designer into NSC component editor, per the user manual the object type drop down box one of the choices is supposed to be 'CAD Part Zemax Part Designer' that then is supposed to point to the .ZPO file created in Part Designer, it doesn't have that choice, in fact the CAD files are only the typical STL and IGES type of files.  I have OpticsStudio Professional 20.2.1.
Best answer by Kevin Scales
Hi Mark,
Thank you for your question to Zemax Support. The CAD Part Zemax Part Designer option for objects is available in Premium but not in Professional versions of OpticStudio. You may upgrade to Premium into order to get this and a few other CAD Part object options.
Kevin Scales
Kevin Scales
  • 185 replies
  • July 7, 2020
Hi Mark,
Kevin Scales
Maria
  • 5 replies
  • July 4, 2022
I am reading the Feature Comparison for subscription licenses at Zemax website https://cdn.shopify.com/s/files/1/0539/4959/5825/files/osdoc_subscription_compareeditions_a4_20-3_092020-en-us.pdf?v=1622161489
It is said here that “Part designer – static parts” is available in professional versions, but “Part designer – dynamic parts” is not. Could someone please explain what the static parts and dynamic parts are and what is the difference between them?
Thanks!
- Maria
Andrew_Davies
I suspect that dynamic parts mean CAD Part: Zemax Part Designer components. These are parts you can draw in the Part Designer and can make aspects of them parametrizable for the Merit function.
jsung
  • 27 replies
  • October 16, 2024
Hi, I’m new to this forum and just signed up to join it.
My question is how to view the coordinate in the sketch mode of Part Designer screen? For example, when I draw several lines to create prism or some polygon section with mouse I don’t see x, y coordinates displayed. Is there setting to display the coordinate of points or mouse location?
  • 1138 replies
  • October 17, 2024
@jsung
For new questions, please consider creating a new topic 😊
In the menu bar of the Part Designer, you will find a square icon looking like a crosshair. I think it is the feature you are looking for:
I hope this helps.
